Normal Topic EBehavior.bhDoNothing Problem (Read 1093 times)
zuoyi
Jul 22nd, 2006 at 6:31am
when i set flowChart1.Behavior = EBehavior.bhDoNothing;
i can't select box,
how to set the box can be select only,no resize,no arrow.
thank you.
Re: EBehavior.bhDoNothing Problem
Reply #1 - Jul 24th, 2006 at 6:13am
It seems you have an older version of the control - there you can set the box.MnpHandlesMask to 256 to allow only moving the box or to 0 to prevent both moving and resizing. Set the Behavior to bhModify to allow only selecting boxes but prevent drawing new items.
If anyone that uses version 4 or newer is interested in this - set box.EnabledHandles to Handles.Move or Handles.None.
HTH
