Normal Topic NodePointed event (Read 2022 times)
jf2020
I love FlowChart!
NodePointed event
Apr 19th, 2012 at 8:13pm
I'm trying to use the NodePointed event but it doesn't seem to fire. Am I doing something wrong?
JF
Re: NodePointed event
Reply #1 - Apr 20th, 2012 at 6:10am
It works in my test app. The event is raised 800 milliseconds after the mouse stops over a node. If you have some links passing over the node, the control might be raising LinkPointed instead; try setting HitTestPriority = NodesBeforeLinks in that case.
jf2020
I love FlowChart!
Reply #2 - Apr 21st, 2012 at 5:59am
Yes. My issue is in the 800ms delay for the event to be fired. I was trying to use the event to modify the mouse cursor and was eager to have the cursor modified as soon as the node was hoovered. I'm now using mousemove and I do the node hit detection myself...
