Hot Topic (More than 10 Replies) XML with French Characters (Read 16997 times)
jprogrammer
Jul 26th, 2006 at 1:40pm
I am trying to open an XML with French characters and I am getting the following error message.
An invalid character was found in text content.
Online
Re: XML with French Characters
Reply #1 - Jul 26th, 2006 at 4:00pm
Do you mean the FlowChart.NET's XmlReader displays that message, or is that related to the XML Viewer tool? And is there an "encoding" attribute in the XML declaration?
jprogrammer
Reply #2 - Jul 26th, 2006 at 5:03pm
Sorry I posted this to the from one.  I ment to post it to the XML Viewer.
This error message comes up when I try to load an XML that contain French characters.
Online
Reply #3 - Jul 26th, 2006 at 5:24pm
Is there an "encoding" attribute in the opening XML tag, and what's its value?
Reply #4 - Jul 26th, 2006 at 6:06pm
* moved here from the FlowChart.NET board *
jprogrammer
Reply #5 - Jul 26th, 2006 at 6:43pm
I opened the XML in UltraEdit and I do not see an encoding tag.  I will email the XML to you.
Reply #6 - Jul 27th, 2006 at 11:33am
I am trying to open the file you sent me with Internet Explorer 7 and it gives exactly the same mistake: "An invalid character was found in text content. Error processing resource." Have you tried this yourself?
This is expected thought, because XML Viewer is acutally based on MS XML DOM, as is Internet Explorer itself. Anyway, I find it particularly weird that the MS DOM is not able to parse the file.
Can you please try loading the file in IE or in any other XML processing appication?
jprogrammer
Reply #7 - Jul 27th, 2006 at 11:59am
I tried another XML viewer and it gave me that the file is not well formed.  I then opened up the XML in Ultra Edit and went to where it said the file was  messed up, this is what was in the file:
<DeptFld HoursPosition="1" ApptRequired="false" HoursText="Lun - Dim : FERMÉ"/>
This is how the other viewer was reading it:
<DeptFld HoursPosition="1" ApptRequired="false" HoursText="Lun - Dim : FERM&#482;/>
It looks like the viewers are have trouble with the comination of É".
any thoughts.
Reply #8 - Jul 27th, 2006 at 12:59pm
It seems that indeed the character 'É' is messing up things. Maybe you should explicitly specify appropriate encoding in the XML file.
By the way, have you tried loading the XML file in Internet Explorer?
jprogrammer
Reply #9 - Jul 27th, 2006 at 1:11pm
Yes I did and I got the same message.
Online
Reply #10 - Jul 27th, 2006 at 1:18pm
Add an <?xml version="1.0" encoding="UTF-16"> to the top of the XML document, save it as an Unicode file, and everything will be ok  8)
jprogrammer
Reply #11 - Jul 27th, 2006 at 1:43pm
Thanks a lot. I can open the file now.
I will let our customer know to add this to all of the XML's that they send us.
