Normal Topic is the bounds of the "edit rect" settabl (Read 4435 times)
azany1
Aug 2nd, 2006 at 3:43am
Is there a way to restrict the bounds of the inplace edit box to a sub-rectangle of a box or table's bounds?
Thanks for any info,
-lipp
Re: is the bounds of the "edit rect" set
Reply #1 - Aug 2nd, 2006 at 6:12am
There is a way to do that - handle the EnterInplaceEditMode event, which gives you access to the TextBox used for editing. You can do whatever you wish with the TextBox, including changing its position, font, selection, etc.
HTH
azany1
Reply #2 - Aug 2nd, 2006 at 6:18am
rock!  completely missed that
thanks again,
-lipp
azany1
Reply #3 - Aug 2nd, 2006 at 6:52am
(Sorry to reply to myself, but...)
Hmm...It looks like Box.BeginInplaceEdit sets things up so that InplaceEditArgs.Item is the (externally) opaque type InplaceEditable.
Is there a way to get to the currently edited node from an EnterInplaceEditMode handler?
Reply #4 - Aug 2nd, 2006 at 7:18am
I see. If you have the source code, add this to InplaceEditArgs:
public Node Node
  get
    if (item is NodeInplaceEditable)
     return (item as NodeInplaceEditable).Node;
    if (item is Table.Cell)
     return (item as Table.Cell).table;
    return null;
Or send me a message to glavcho@mindfusion.org and I will send you some fresh dlls  Grin
azany1
Reply #5 - Aug 2nd, 2006 at 7:33am
got it; i'll give the patch a try in a bit
thanks,
-lipp
azany1
Reply #6 - Aug 2nd, 2006 at 4:21pm
Ok, next problem: in V4.2 of FlowChart.NET, InplaceEditable doesn't have a field called "item" (or, any fields for that matter).
Reply #7 - Aug 3rd, 2006 at 6:26am
Add that to InplaceEditArgs and not to InplaceEditable  Roll Eyes
azany1
Reply #8 - Aug 3rd, 2006 at 4:23pm
doh!  that worked; so, this will be in the next release?
thanks again,
-lipp
Reply #9 - Aug 4th, 2006 at 6:42am
yes, it will be there.
