Normal Topic Creating new controlpoint via sourcecode (Read 2029 times)
Dirk Woelfel
Aug 3rd, 2006 at 11:10am
Hello, itīs me again  Wink
I try to add a new controlpoint/segment to an existing arrow when the user clicks on the arrow.
My sourcecode:
tmpArrow = Me.FlowChart1.GetArrowAt(Pt, 1, True, segNo)
tmpArrow.ControlPoints.Insert(segNo + 1, Pt)
tmpArrow.UpdateFromPoints()
After doing this the arrow consists of 2 segments, but the second one is not visible. I get one segment from arrow-startpoint to new control point (in origin arrow style) and a second one from new control point to arrow-endpoint (line ist not visible - just the arrowhead is there).
Another question: how can I check if an existing controlpoint ist hit by mouseclick?
Any idea?
Dirk
Re: Creating new controlpoint via sourcecode
Reply #1 - Aug 3rd, 2006 at 12:16pm
Hey, it's you!!!  Grin
There isn't any nice way to insert control points. First you must increase the SegmentCount property, but that resets the current arrow shape to a straight line, so you must keep a copy of the old control point positions.
Take a look at the MouseMove handler here:
http://mindfusion.org/cgi/Forum/YaBB.pl?board=fcnet_disc;action=display;num=1152...
Just change points.Add(point); to points.Insert(..., point);
- glavcho
Reply #2 - Aug 3rd, 2006 at 12:29pm
Call the HitTestHandle method to find out whether any control point is hit.
HTH
Dirk Woelfel
Reply #3 - Aug 4th, 2006 at 10:00am
Thank you,
works fine! Great support!
