Normal Topic ArrowCreated (Read 1329 times)
Cliven yong
Guest
ArrowCreated
Aug 8th, 2006 at 5:04am
Dear Sir
I have some problem during ArrowCreated Event.
When this event fire try to execute below the code
FC.Arrows.Remove(e.Arrow)
FC doesn't remove the arrow in the UI and still allow me to select the arrow. If after select the arrow and press delete button. FC raise a error
An unhandled exception of type 'System.ArgumentException' occurred in mscorlib.dll
Additional information: Cannot remove the specified item because it was not found in the specified Collection.
Please reply me asap
Thank you
Cliven
Re: ArrowCreated
Reply #1 - Aug 8th, 2006 at 6:02am
Dear Cliven,
Call fc.DeleteObject(e.Arrow) to delete the arrow. Otherwise you would have to remove the arrow from several more collections - fc.Objects, origin_node.OutgoingArrows and destination_node.IncomingArrows. DeleteObject also creates an undo/redo record and repaints the flowchart.
