Normal Topic BoxCreated not raised (Read 1396 times)
Peter
Aug 23rd, 2006 at 3:11am
It seems that the BoxCreated event does not get raised when the flowchart's method CreateBox is used to make a new chart element. The event gets raised when a box is created interractively. Is this a feature or a bug, or am I doing something wrong?
Re: BoxCreated not raised
Reply #1 - Aug 23rd, 2006 at 5:23am
Most of the events are raised only after user actions. If you need to execute the same code for boxes created interactively or through the API, move the shared code to a separate method and call that method after calling CreateBox and from the BoxCreated handler.
