Normal Topic arrow instance unavailable in ValidateAnchorPoint (Read 2363 times)
azany1
Aug 15th, 2006 at 1:56am
When dragging one endpoint of an arrow instance, my ValidateAnchorPoint handler is called, but args.Arrow seems to always be null.
Is there something I'm not setting up properly?
-lipp
Re: arrow instance unavailable in ValidateAnchorPo
Reply #1 - Aug 15th, 2006 at 5:26am
You can ignore the event when args.Arrow is null. The control raises that event once for each anchor point in a node without specifying an arrow, in order to determine whether the node accepts any arrows at all. After that the event is raised again for the arrow that the user draws at that time.
azany1
Reply #2 - Aug 16th, 2006 at 5:02pm
Ahh...thank you.
As a related point, the documentation for AttachConfirmArgs doesn't mention the "Node" field.  What is that for?
Thanks again,
-lipp
Reply #3 - Aug 17th, 2006 at 6:10am
Node is the same node as either Origin or Destination, depending on which end of the arrow is being moved.
