One way you could do that is by using two Transparent boxes inside the legend box and create the arrows between them. Another way is by using anchor points as shown below.
' define the legend box points where the arrows should connect
Dim legendAnchors As New AnchorPattern
legendAnchors.AddAnchorPoint 5, 25, True, True, msCircle, vbRed
legendAnchors.AddAnchorPoint 95, 25, True, True, msCircle, vbRed
legendAnchors.AddAnchorPoint 5, 50, True, True, msCircle, vbRed
legendAnchors.AddAnchorPoint 95, 50, True, True, msCircle, vbRed
legendAnchors.AddAnchorPoint 5, 75, True, True, msCircle, vbRed
legendAnchors.AddAnchorPoint 95, 75, True, True, msCircle, vbRed
legendAnchors.PatternId = "legend"
Dim labels(3) As String
labels(0) = "strong bind"
labels(1) = "weak bind"
labels(2) = "no bind"
Dim shapes(3) As EArrowHead
shapes(0) = ahTriangle
shapes(1) = ahArrow
shapes(2) = ahNone
' create the legend box
Dim legendBox As box
Set legendBox = fcx.CreateBox(50, 50, 200, 200)
legendBox.AnchorPattern = legendAnchors
' create the legend arrows
Dim legendArrow As arrow
Dim i As Integer
For i = 0 To 2
Set legendArrow = fcx.CreateArrow(legendBox, legendBox)
legendArrow.Text = labels(i)
legendArrow.ArrowHead = shapes(i)
' clear any anchor points chosen by CreateArrow
legendArrow.OrgnAnchor = -1
legendArrow.DestAnchor = -1
' specify anchor points from the pattern define above
legendArrow.OrgnAnchor = i * 2
legendArrow.DestAnchor = i * 2 + 1
' reflexive arrows are created as Bezier
' so align their middle control points to the end points
legendArrow.CtrlPtY(1) = legendArrow.CtrlPtY(0)
legendArrow.CtrlPtY(2) = legendArrow.CtrlPtY(0)
legendArrow.Update
Next i
It seems the control does not let you to create a reflexive "polyline" arrow that has only one segment, so the code above just uses the default Bezier style and aligns the middle points to the end points.
