Normal Topic Add appointment by double-clicking (Read 1722 times)
Josh
Guest
Sep 10th, 2006 at 9:55pm
Is it possible to double-click an open space in the calendar view and pop up an Appointment window to create an event?  My understanding is that you must type the subject in the open space, then double click it and edit from there.
Thanks a lot,
Josh
Re: Add appointment by double-clicking
Reply #1 - Sep 11th, 2006 at 4:39am
You can handle the DateClick event and display the appointment creation window in it. You can check the Clicks property of the corresponding event data object to determine the number of times the mouse button was pressed. A value of 2 means that the button was double-clicked.
