Normal Topic Hosting SDI with Flowchart in ActiveX (Read 3528 times)
nikogo
Sep 12th, 2006 at 6:23am
I have created MFC SDI App with view derived from CFormView which hosts FlowChart. It works fine
including flowchart item removing by pressing Del key.
But when I creates MFC ActiveX with SDI interface which hosts FlowChart in its formview, revoming
items by pressing Del key doesn't works.
Please could you help me to resolve this issue?
Re: Hosting SDI with Flowchart in ActiveX
Reply #1 - Sep 12th, 2006 at 8:46am
That means that the flowchart does not get a WM_KEYDOWN message when Del is pressed. Try that with the fHandleDelInTranslAcc bit in the KeyboardFlags property set to TRUE - then the FlowChart will handle Del if it is passed to it through the PreTranslateAccellerator COM API function.
nikogo
Reply #2 - Sep 12th, 2006 at 10:07am
I have a look at flowchart's window messages by using Microsoft Spy++. The spy logs that flowchart window (class name FCX_PRO) receives WM_KEYDOWN/WM_KEYUP with VK_DELETE when I press Del key on flowchart.
What could this mean? Is it OK?
Reply #3 - Sep 12th, 2006 at 12:06pm
The message might be intercepted by a hook function in the parent control, or maybe ATL reflects the message to the parent. Then if the parent window handles that key, it won't reach the flowchartx message handler. I believe the first thing happens - MFC forms hook into their child controls' message queues and intercept keys such as tab, del, the arrow keys...
Have you tried setting that bit in KeyboardFlags?
nikogo
Reply #4 - Sep 13th, 2006 at 1:10pm
Yes, I have set KeyboardFlags to FALSE. Now items can be removed from flowchart by pressing Del key. Smiley
