Hot Topic (More than 10 Replies) MouseWheel? (VB.Net) (Read 7287 times)
Mark_Wills
Sep 19th, 2006 at 9:43am
Has anyone found out how to scroll the flow chart client area using the mouse wheel?
I found an example in C# on this forum from January, but I don't understand it at all!
Anyone done it in VB?
kind regards
Mark Wills
Re: MouseWheel? (VB.Net)
Reply #1 - Sep 19th, 2006 at 10:22am
Implement the MouseWheel event handler like this:
Private Sub fc_MouseWheel(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles fc.MouseWheel
  Dim fcSender As FlowChart = sender
  Dim newScrollY As Single = fcSender.ScrollY - e.Delta / 50
  If newScrollY > fcSender.DocExtents.Top Then _
    fcSender.ScrollY = newScrollY
End Sub
For some reason the MouseWheel event is not visible from the C# form editor, but VB.NET displays it fine in the form events combo box.
Mark_Wills
Reply #2 - Sep 19th, 2006 at 11:31am
Thanks Stoyan:
That doesn't look right to me... Are you thinking of CType()?
The code doesn't build as written.
Or maybe you're thinking of Dim fcSender As NEW FlowChart = sender ????
Regards
Mark
Reply #3 - Sep 19th, 2006 at 11:41am
It works fine in my VS2003 test project. What error message did the compiler show? Do you use the "Option Strict" compiler directive?
Regards
Reply #4 - Sep 19th, 2006 at 11:47am
This should work fine with "Option Strict":
  Dim fcSender As FlowChart = CType(sender, FlowChart)
  Dim newScrollY As Single = fcSender.ScrollY - e.Delta / 50.0F
End Sub
Mark_Wills
Reply #5 - Sep 19th, 2006 at 12:08pm
Thanks Stoyan,
Yes, I use option strict 'everything'  Smiley
Yes, I thought you wanted a CType in there somewhere!
Also, it didn't like 'FlowChart' but thats because I don't use the Imports directive - I prefer to use the fully qualified names - makes lines longer, but you know exactly whats going on!
I'll give this a try!
Mark.
Mark_Wills
Reply #6 - Sep 19th, 2006 at 12:12pm
Perfect Stoyan,
You rock!
Here's the code I used in the end:
       Dim fcSender As MindFusion.FlowChartX.FlowChart = CType(sender, MindFusion.FlowChartX.FlowChart)
       Dim newScrollY As Single = fcSender.ScrollY - e.Delta / 20.0F
Definatley more long winded, but as I said, still being on the .Net learning curve, I don't like to assume anything!
Regards
Mark
Reply #7 - Sep 19th, 2006 at 12:29pm
heinrich
Reply #8 - Feb 15th, 2007 at 10:32am
Have anyone done this with Delphi 2006 (WinForms not VCL)?
/Heinrich
Reply #9 - Feb 16th, 2007 at 5:57am
Should look like this in Delphi:
procedure TWinForm1.FC_MouseWheel(sender: System.Object; e: MouseEventArgs);
var newScrollY : Single;
begin
	newScrollY := System.Single(fc.ScrollY - e.Delta / 20);
	if newScrollY > fc.DocExtents.Top then
     begin
	 fc.ScrollY := newScrollY;
     end;
end;
heinrich
Reply #10 - Feb 16th, 2007 at 6:30am
Thank you, I will try this at once.
Smiley
/Heinrich
heinrich
Reply #11 - Feb 16th, 2007 at 7:09am
Hi again
The code seems ok, but nothing happens.
It seems like no call from Delphi to this procedure is done. Do you know from where it should be called?
Mark_Wills
Reply #12 - Feb 16th, 2007 at 7:15am
I know nothing about Delphi, but the code, as written seems to be a standard 'procedure', as opposed to an event.
Thus, I would summise that an event handler would have to be set up, such that when the mousewheel event fires, it called the procedure.
Regards
Mark
Reply #13 - Feb 16th, 2007 at 2:12pm
You must attach the procedure to the event  -
Include(Self.fc.MouseWheel, Self.FC_MouseWheel);
heinrich
Reply #14 - Feb 19th, 2007 at 5:50am
Thanks a lot. This made it work.
Smiley
/Heinrich
