Normal Topic drawing L shape arrows and regarding visio export (Read 2504 times)
gokul
Sep 20th, 2006 at 10:15am
hi
1) presently flowchart control draws straight line only.can i draw L shape or different shape arrows(lines to show relations) .any other way..?
2) when i m using visioExporter its not exporting the file.but when i m trying pdf its working perfectly.
       Dim ts As New VisioExporter
       Dim s As New PdfExporter
       ts.Export(FC, "C:\rv.VDX")
       s.Export(FC, "C:\rp.PDF")
Re: drawing L shape arrows and regarding visio exp
Reply #1 - Sep 20th, 2006 at 10:25am
Set the default ArrowStyle property to Cascading or Bezier to let users draw L-shape arrows or curved ones.
VisioExporter requires the VisioExport.vxt template file to be present in the directory where your application .exe file resides, or in the one specified through the TemplatePath property.
