Normal Topic Save to HTML (Read 1152 times)
archana
Save to HTML
Sep 29th, 2006 at 8:12pm
I am using Flowchart.net 3.2 and I want to save my diagram as an html file. Is it possible to do it with version 3.2. I looked through the other discussions and found that pdfExpoter can be used to export to pdf file. But it is for version 4.2 and up I guess.
Please advice!
thanks,
archana
Re: Save to HTML
Reply #1 - Sep 29th, 2006 at 8:34pm
Use the CreateImageHtml method of HtmlBuilder to export an image and an html file. HtmlBuilder should be available in version 3 of the control. The exported html file will contain an image map whose AREA tags correspond to the box shapes, and whose HREF values are set to the box Hyperlink. You can use the other methods of HtmlBuilder to get image map code that you can embed into your own html pages.
