Normal Topic AttachProportional only on X or Y (Read 1451 times)
feugen24
Oct 10th, 2006 at 8:08am
If I want to have 2 attached boxes (move together, resize together) but first should resize only when the second changes it's height but not width;  Attach Proportional is not good because it's both for height/width.
I can attach normaly and when MouseDown event is fired(NS cursor) I can detach them and then at BoxModifying event Resize the first box and reatach them at BoxModified...but in this case the first box has a visible delay when resizing. What other options do I have?
An attachproportional with only width/height should be usefull.
Tks.
Re: AttachProportional only on X or Y
Reply #1 - Oct 10th, 2006 at 8:54am
Groups in version 4.2.1 let you anchor child nodes to the edges of their parent node, similar to how the Anchor property of controls works in Windows Forms. You could use the Node.AttachTo(Node, GroupAnchorStyles) overloaded method or the Group.AttachToEdges method.
feugen24
Reply #2 - Oct 13th, 2006 at 7:55am
Very nice improvement "Node.AttachTo(Node, GroupAnchorStyles) ". It saves a lot of code and tricks to do when working with attached objects.
It solved this and other problems.
Tks.
