Normal Topic How to trap "del key" click in JavaScrip (Read 3749 times)
just2click
Go Sharks Go
Oct 11th, 2006 at 5:01am
I'm new here. I trying to add some feature related to the deletion of objects from the display.
I can't find an example of how to wire the event and trap it within JavaScript.
Any pointers?
Dror
Re: How to trap "del key" click in JavaS
Reply #1 - Oct 11th, 2006 at 6:35am
You will have to disable the standard keyboard processing if you wish to handle the Del key yourself. You must also set one of the KeyboardFlags that makes FlowChartX handle key-down messages through a COM interface instead of the Windows Message Queue:
<SCRIPT language="JavaScript">
function window_onLoad()
  fcx.KbdActive = false;
  fcx.KeyboardFlags(2) = true;
</SCRIPT>
<SCRIPT FOR="fcx" EVENT="KeyDown(keyCode, shift)">
  if (keyCode == 0x2E)
    alert("Del");
</SCRIPT>
just2click
Go Sharks Go
Reply #2 - Oct 15th, 2006 at 7:01am
Thanks  Stoyo Grin
I already did some of it. Does disabling the keboard affects any other key strocks handling?
Thanks again
Dror
Reply #3 - Oct 16th, 2006 at 8:33am
Hi Dror,
That will also disable the clipboard combinations - Ctrl+X/C/V and the undo/redo ones - Ctrl+Z/Y.
Reply #4 - Oct 21st, 2006 at 7:25am
Actually you don't have to set KbdEnabled = false to get the KeyDown event for Del. You only need to set EventFlags(fFireKeyDownOnDelete) = true. Thus you can still use the standard handling for the other keyboard shortcuts.
