Normal Topic Porblem with the clearAll function (Read 1548 times)
cas_ramos
Oct 17th, 2006 at 9:41am
I.
I'm having a problem with the function clearAll(). When executing a function (that draws the workflow) from the boxcreated property to redraw everything, the component "explode" giving a message "Object reference not set to an instance of an object." and shows the assembly window. The problem can't be from the code because i have a try..catch block and do not enter in the cacth state.
Best regards,
Carlos Ramos
Re: Porblem with the clearAll function
Reply #1 - Oct 17th, 2006 at 11:52am
It seems the control does not expect ClearAll to be called from BoxCreated, and uses the reference of the just created-box after the event. You could work around that by deleting the items as follows:
private void fc_BoxCreated(object sender, MindFusion.FlowChartX.BoxEventArgs e)
while (fc.Boxes.Count > 0)
fc.DeleteObject(fc.Boxes[0]);
DeleteObject sets a flag that makes the flowchart MouseUp handler exit immediately after raising BoxCreated, which prevents using the reference to the deleted box.
cas_ramos
Reply #2 - Oct 18th, 2006 at 8:06am
OK. That resolved my problem. Thanks.
Carlos Ramos
