Normal Topic Sotping Collapse (Read 4359 times)
just2click
Go Sharks Go
Sotping Collapse
Oct 18th, 2006 at 9:47am
Hi again,
Thanks for your help the last time.
I have yet another question.
Is it possible to trap the actual 'collapse' event and change it?
I have a situation where I'm using a tree type graph. It is however possible to have "weak" relations between sibling (i.e. the have a common child).
My problem is that whenever I try to collapse the sibling FlowChart "sees" as parent it collapses the other sibling to.
Is there a way to prevent this?
Thanks in advnace,
Dror
Re: Sotping Collapse
Reply #1 - Oct 18th, 2006 at 10:30am
Yes, you could set the flowchart.EventFlags(fOverrideTreeExpanding) = true and handle the BoxExpanded and BoxCollapsed events to implement your own expand/collapse logic. If in some situation you could use the standard expand functionality, call the Expand or Collapse methods of the Box class.
just2click
Go Sharks Go
Reply #2 - Oct 18th, 2006 at 12:47pm
Thanks Stoyo it did the trick  Roll Eyes
just2click
Go Sharks Go
Partial Collapse Stoping?
Reply #3 - Oct 23rd, 2006 at 5:57am
Hi again,
Following my original question, is it possible to trap and handle only some of the collapse click (when event flags fOverrideTreeExpanding is false).
I'm having problems when I try to handle collapsing of boxes within a container.
My predecessor have developed a method that recursively collapses a try. This method is used outside the box ( Roll Eyes). When applied within the box it crashes the entire ActiveX.
Any suggestions?
Thanks in advance,
Dror
Reply #4 - Oct 23rd, 2006 at 7:42am
There is no way to prevent the event from firing for some boxes. Can't you check if the clicked box is in a container and if so - don't call that method?
just2click
Go Sharks Go
Reply #5 - Oct 23rd, 2006 at 7:57am
Thanks again for your timly response.
I tried that.
The problem is that if I turn FC collapse event off I cannot use it inside the container (which gives me better results inside). On the other hand, when I enable FC collapse it collapses every box it identifies as a child (logically). My application includes several types of relations and I only need to collapse a specifc type.
Is it at all possible?
Dror
Reply #6 - Oct 23rd, 2006 at 9:16am
Why can't you use it inside the container - isn't the event raised if a box is contained within another one?
just2click
Go Sharks Go
Reply #7 - Oct 23rd, 2006 at 11:17am
Thanks Stoyo man
I've resolved it in a different way.
I'm manually deleting both arrows and boxes thus ensuring no object is left un handled.
