Normal Topic Textformat.alignment (Read 1681 times)
ampersand
Oct 22nd, 2006 at 8:02pm
I want to set the text alignment of a box when the user clicks a toolbutton. So I used the following code in my click event.
(flowChart.ActiveObject as Box).TextFormat.Alignment = StringAlignment.Near;
But the box does not show any effect until I resize or move the box. Only then the text is aligned to the left side.
What is going wrong?
Dirk
Re: Textformat.alignment
Reply #1 - Oct 23rd, 2006 at 7:01am
StringFormat is a standard .NET class and FlowChart.NET cannot detect changes done to the StringFormat properties. You could either assign a whole StringFormat object to the Box.TextFormat, or explicitly call FlowChart.Invalidate after changing Box.TextFormat.Alignment.
Reply #2 - Oct 23rd, 2006 at 7:04am
Invalidating won't be enough if using polygonal text layout or styled text, so it might be better to assign a new StringFormat object to the Box.TextFormat.
ampersand
Reply #3 - Oct 23rd, 2006 at 7:50am
Perfect !
Here's my code for alignment left, in case others have the same problem:
StringFormat format = new StringFormat();
format.Alignment = StringAlignment.Left;
format.LineAlignment = StringAlignment.Center;
(flowChart.ActiveObject as Box).TextFormat = format;
Dirk
