Normal Topic Print Preview and printing prob (Read 2119 times)
Phil Jacques
.NET 2.0 Rocks!!!
Oct 23rd, 2006 at 12:45pm
I have drawn a diagram of some 30 boxes and some 35 connections on FC.NET control.
Each of the boxes have a text property which is set to some text.
When i do a print preview (print preview ex) of this diagram it shows nicely.
however when i say "FitToPage", it retains the same font size, but the boxes are scaled to a lesser size.
This makes the diagram look messy and not good.
Can you please suggest something to make the font size of the box to scale and fit accordingly?
Thanks in advance
Cheers
Phil
ampersand
Re: Print Preview and printing prob
Reply #1 - Oct 23rd, 2006 at 2:21pm
Hi Phil,
you have to use GraphicsUnit.World when creating the fonts, then the fonts scale smoothly.
Dirk
Phil Jacques
.NET 2.0 Rocks!!!
Reply #2 - Oct 24th, 2006 at 6:18am
When i change the Font.Unit property to GraphicsUnit.World, the fonts do not display on the boxes.
I attempted to change the Font.Unit property of the Flowchart  object.
What could be the problem?
Thanks in advance
Cheers
Phil
Reply #3 - Oct 24th, 2006 at 6:32am
Using World as the font size unit will make the font manager use the flowchart's MeasureUnit, which is millimeters by default. So you might have to use a smaller value for the font size when specifying it in millimeters, e.g. try with 2.5 or 3.
Phil Jacques
.NET 2.0 Rocks!!!
Reply #4 - Oct 24th, 2006 at 6:58am
Thanks a Ton Stoyan.
You are a genius ....  Smiley
Cheers
Phil
