Page Index Toggle Pages: 1 2 [3]  Send TopicPrint
Very Hot Topic (More than 25 Replies) Export Issues (Read 12613 times)
netmond
Re: Export Issues
Reply #30 - Dec 15th, 2006 at 2:57pm
hey,
it seem we have a similar problem - when i do a get latest on a solution which depends on an flowchart.net driven project it i get a:
Error168Exception occurred creating type 'MindFusion.FlowChartX.FlowChart, FlowChart.NET, Version=4.2.1.26908, Culture=neutral, PublicKeyToken=a0d18338041985ba' System.ComponentModel.LicenseException: Couldn''t get design-time license for ''MindFusion.FlowChartX.FlowChart''V:\C#\SHSP\Swisscom.IT.SHSP.WorkflowAddin\Pro
perties\licenses.licx1Swisscom.IT.SHSP.WorkflowAddin
even if do a complete flowchart.net installation
i don't want to work with this component, i just want to be able to do a complete rebuild - the best would be without installing flowchart.net
what's wrong ?
thanks in advance
edmond
Re: Export Issues
Reply #31 - Dec 15th, 2006 at 4:21pm
If you need to rebuild a project without installing the full package, you will have to at least copy the design-time license to your registry. On a system where the control is installed, open the following key in regedit
HKEY_LOCAL_MACHINE\SOFTWARE\MindFusion Limited\ComponentLicenses
and export it to a file, then copy it to your system and import it there.
Version 4.2.2 of the control looks for a MindFusion.Diagramming.WinForms.FlowChart value under that key, while in older versions you will need a MindFusion.FlowChartX.FlowChart value.
Re: Export Issues
Reply #32 - Dec 15th, 2006 at 4:22pm
... additionally, if you have upgraded to version 4.2.2, you will need to rename the class name in the .licx file to"MindFusion.Diagramming.WinForms.FlowChart".
