Normal Topic Prblems installing XML Viewer (Read 5378 times)
SalPalg
Oct 27th, 2006 at 10:09am
hi
I have tried opening the saved verison as well as opening it from the Mind Fusion site directly and i doesn't seem to load.  A pop up window appears for a milli second (cant read message) and it disappears with out loading.
Can anyone suggest anything?
S
Re: Prblems installing XML Viewer
Reply #1 - Oct 27th, 2006 at 10:55am
The MSI installer might fail if you open the .msi package from a network drive or from an encrypted NTFS folder.
SalPalg
Reply #2 - Oct 27th, 2006 at 11:13am
Hi Stoyo,
Many thanks for your response,
It was being opened from my desktop so i dont see that being an issue but i will check if it is encryped NTFS
