Normal Topic TextSelection in Box (Read 2220 times)
ampersand
Nov 7th, 2006 at 8:58am
In my app I modified the behaviour of editing a Box. When the user selects a box and starts pressing keys, the box automatically switches to inplace editing mode.
private void btChart_KeyPress(object sender, KeyPressEventArgs e)
  if (btChart.ActiveObject != null)
    if (btChart.Selection.Objects.Count == 1)
	if ((Char.IsLetterOrDigit(e.KeyChar)) || (Char.IsPunctuation(e.KeyChar)) ||
(Char.IsSeparator(e.KeyChar)) || (Char.IsSymbol(e.KeyChar)))
	  if (btChart.ActiveObject.GetType() == typeof(Box))
	    (btChart.ActiveObject as Box).Text += e.KeyChar;
	    (btChart.ActiveObject as Box).BeginInplaceEdit();
I now have the problem, that as soon as I press a key, and BeginInplaceEdit is called the text in the Box is selected and will be deleted if the user continues typing.
How can I prevent Box from selecting text, when BeginInplaceEdit is called or how can i deselect the text?
Is it possible to move the text cursor to a certain position in the text, let's say the end of the text? I couldn't find a function for it yet.
Dirk
Re: TextSelection in Box
Reply #1 - Nov 7th, 2006 at 9:10am
Handle the EnterInplaceEditMode event. It gives you a reference to the TextBox control used for editing. Use the TextBox methods to change the selection or move the cursor to the end.
ampersand
Reply #2 - Nov 7th, 2006 at 11:16am
Thanks, that did the trick.
But I came over another issue. When I edit a Box and press ESC and immediately press a key afterwards it seems that the keyDown and Keypress event of the flowchart are not fired anymore. Only if I Click again on the same object (which is still the activeObject) the Key events are working again.
What am I doing wrong?
Dirk
Reply #3 - Nov 7th, 2006 at 11:26am
Perhaps the keyboard focus is not on the flowchart. Try calling the Control.Focus method from the LeaveInplaceEdit event handler.
