Normal Topic Start Node for faster Layouting (Read 2188 times)
Phil Jacques
.NET 2.0 Rocks!!!
Nov 9th, 2006 at 2:41pm
Stoyan,
Somewhere i read that if i provide the starting node, the spring/grid layout will be much faster.
Please let me know if this is true, and how to achieve that?
Cheers
Phil
Re: Start Node for faster Layouting
Reply #1 - Nov 10th, 2006 at 5:50am
Hello Phil,
Setting the start and end nodes will improve the grid layout speed only when arranging the graph around the longest path. In that case the control will look for a path only between the specified nodes, which is faster compared to looking for paths between all node pairs.
Phil Jacques
.NET 2.0 Rocks!!!
Reply #2 - Nov 10th, 2006 at 5:52am
Hello Stoyan,
Thanks for your faster reply,
I can set a start node in Spring Layout so that the layouting occurs around that node.
Can i specify this by the root property of the Spring Layout?
Phil
Reply #3 - Nov 10th, 2006 at 6:20am
Hello Phil,
By setting the SpringLayout.Root property, you specify what subgraph in the diagram to arrange. The subgraph would contain all nodes that can be reached by starting from the root and following the links. If you diagram contains several such unconnected subgraphs, the Root lets you arrange just one of them. There's a chance that the other nodes will be arranged around the root if it's a central node in the subgraph.
