Normal Topic Box location (Read 3693 times)
Phil Jacques
.NET 2.0 Rocks!!!
Box location
Nov 14th, 2006 at 8:06am
Stoyan,
Seems quite trivial, but please tell me how do i get the position of the box on the flowchart.
I could not see anything as Box.location, Box.X, Box.Y or something like this on the Box object.
Please let me know.
Thanks in advance
Cheers
Phil
Re: Box location
Reply #1 - Nov 14th, 2006 at 8:13am
Hello Phil,
Use the box.BoundingRect property.
Phil Jacques
.NET 2.0 Rocks!!!
Re: Box location
Reply #2 - Nov 14th, 2006 at 8:17am
Stoyan,
That gives me the RectangleF, whereas i would want a PointF of the center of the box.
Phil
Phil Jacques
.NET 2.0 Rocks!!!
Re: Box location
Reply #3 - Nov 14th, 2006 at 8:30am
Ok Got that ..... from the RectangleF i can compute the upper left cooordinates and use the width and height to get the center of the Box.
I was thinking whether i could get these directly.
Being a bit lazy ... Cheesy
Thanks a ton
Phil
Re: Box location
Reply #4 - Nov 14th, 2006 at 8:36am
Here's a method from the control's source code, so you don't get tired  8)
internal static PointF getCenter(RectangleF rect)
  return new PointF(rect.X + rect.Width / 2, rect.Y + rect.Height / 2);
Phil Jacques
.NET 2.0 Rocks!!!
Re: Box location
Reply #5 - Nov 14th, 2006 at 8:49am
Stoyan,
Thanks a ton .... u know what, i was wondering to call up a consultant on how would i get the center of the bounding rectangle from upper left corner.
Thanks for saving my money .... U r genius  Cheesy Wink
Phil
Re: Box location
Reply #6 - Nov 14th, 2006 at 9:51am
Grin
