Normal Topic Locked and Selectable? (Read 2255 times)
Phil Jacques
.NET 2.0 Rocks!!!
Nov 15th, 2006 at 1:00pm
Stoyan,
I am having another bumper, i need the boxes and arrows to be locked, but be able to detect user clicks on them?
Is it possible? Can a locked control fire a mouse click event?? Shocked
Secondly when i set visible=false on boxes, the disappear from the flowchart collection (Cannot use flowchart.FindBox). is this expected behavior? Roll Eyes
What is the way to find hidden boxes and make them visible. (Apart from foreach on all boxes on flowchart.boxes etc). ???
Thanks in advance
Cheers
Phil
Re: Locked and Selectable?
Reply #1 - Nov 15th, 2006 at 1:19pm
Hello Phil,
Yes, BoxClicked and ArrowClicked are raised for locked objects. It is also possible to set Box.EnabledHandles = None. That will let users select a box, but not move it.
FindBox should work pretty well with invisible boxes. Are you sure you don't have some boxes that share the same Tag? - that would make FindBox find only the first box.
Cheers,
Phil Jacques
.NET 2.0 Rocks!!!
Reply #2 - Nov 24th, 2006 at 1:18pm
Hello Stoyan,
Backl after a break ... holidaying at a small and remote lake ....  Smiley
EnabledHandles property is there on the box, but it is not documented i think. I could not find it in the chm.
Findbox on invisible is not working on my flowchart, let me check my code, i must be doing something which would be removing it from the flowchart.
It seems search is linear, since it takes some split seconds more to search, but its ok.
Thanks for the reply
Cheers
Phil
Phil Jacques
.NET 2.0 Rocks!!!
Reply #3 - Nov 24th, 2006 at 1:27pm
I found the property on the Node class. Ignore this one ...
Phil
Reply #4 - Nov 24th, 2006 at 2:10pm
Caught any fish?  Wink
