Normal Topic Can set ControlHost border to 0? (Read 2233 times)
LongRunner
Nov 27th, 2006 at 4:09am
Dear All,
I am a beginner on The FlowChart.NET Pro (version 4.2.1). I got a problem on it.
I created two ControlHost, one in X = 0, Y = 0, Width = 200, Height = 200, the second in X = 200, Y = 0, Width = 200, Height = 200,
And I found that a gap is between the two ControlHost so that they cannot touch each others on the display.
I guess some spaces are spent on the border of the ControlHost.
How can I set this border to zero in this version?
Thanks.
LongRunner
Re: Can set ControlHost border to 0?
Reply #1 - Nov 27th, 2006 at 4:10am
Code attach:
private void button1_Click(object sender, System.EventArgs e)
ControlHost ch = this.fc.CreateControlHost(0, 0, 200, 200);
PictureBox pic = new PictureBox();
pic.BackColor = Color.Black;
pic.Enabled = false;
ch.Control = pic;
private void button2_Click(object sender, System.EventArgs e)
ControlHost ch = this.fc.CreateControlHost(200, 0, 200, 200);
ch.Control = pic;
Reply #2 - Nov 27th, 2006 at 6:30am
There is always some empty space left between the ControlHost.BoundingRect border and the control itself. That's to let you select ControlHost nodes by clicking in this area, for situations in which FlowChart.NET cannot detect mouse-clicks on the control.
At this time that's hard-coded, but we will add a new property to the 4.2.2 release that will let you change the size of that border.
LongRunner
Reply #3 - Nov 28th, 2006 at 1:16am
ic. Thanks for your reply.
However, would you mind build a version to me that fixed this problem? Because i use it urgent.
And when does the 4.2.2 release deploy?
Thanks a lot.
Reply #4 - Nov 28th, 2006 at 6:34am
We are releasing it in a couple of days. I will send you our daily builds if it's more urgent than that.
