Normal Topic Clickable organization chart. (Read 2319 times)
GDIDev
Nov 27th, 2006 at 6:19am
Have anybody tried to make an organization chart that can be click to show more child level using flowchart.net component?
Thx for answering.
Re: Clickable organization chart.
Reply #1 - Nov 27th, 2006 at 6:37am
You can do that by handling the BoxClicked event and adding more items to the tree below the clicked box. Use the TreeLayout class to arrange the newly added nodes.
Take a look at this example, which does something close to what you need. It is in JavaScript, but should it should be easy to implement it in C#:
http://mindfusion.org/cgi/Forum/YaBB.pl?board=netdg_disc;action=display;num=1164...
GDIDev
Reply #2 - Nov 28th, 2006 at 12:00am
if i want to build in aspx file, so i have to used webchart.net? do you have any sample of using webchart.net? thx...
Reply #3 - Nov 28th, 2006 at 6:01am
There is the WebApp sample project installed with FlowChart.NET. It creates jpeg images and html image maps representing flowcharts on the server side.
The Hyperlink property of an item will let you handle mouse click for that item, e.g. you could add an argument to the URL
box.HyperLink = "/Expand.aspx?node=1";
and in Expand.aspx expand the hierarchy that starts from node 1.
