Normal Topic Problem about Node and Group (Read 2255 times)
airmix
Dec 1st, 2006 at 2:33am
There is a group structure, A group has B .......
node struct is
{A -> B -> C -> D}
first delete C , then delete B and add E after D. Next delete D and add F after E. Finally delete E
At this moment, Null Reference Exception happen!!!
I dont understand why error will occur, plz help!!
Box de = userChart.Selection.Boxes[0];
Group parent = box.MasterGroup;
Group sub = box.SubordinateGroup;
Box main = ((Box)parent.MainObject);
Group master = userChart.FindGroup(main.Tag);
for(int i = 0; i < sub.AttachedObjects.Count; i++)
     Box b = (Box)sub.AttachedObjects[i];
     master.AttachedObjects.Add(b);
     master.AttachToCorner(b,0);
     Arrow link = userChart.CreateArrow(main, b);
userChart.DeleteObject(de);
rearrange(); <----- Refresh treelayout
Thx All
Re: Problem about Node and Group
Reply #1 - Dec 1st, 2006 at 5:32am
Calling
will automatically add b to "master.AttachedObjects". Try that without the
line. Otherwise you will end up with two references to "b" in the collection and that might lead to problems.
airmix
Reply #2 - Dec 1st, 2006 at 5:57am
Thanks for your fast reply!!! Grin
But also not work
at last Node E does not contain any Master Group
(origial design is A will contain E, then i could delete E too, but i want to delete E, Null Reference in the MasterGroup and its MainOject)
Help!!!! Stoyo
THX
Reply #3 - Dec 1st, 2006 at 6:34am
What does "add E after D" mean? Could you email me your initial diagram from which I should start deleting and adding stuff?
Reply #4 - Dec 1st, 2006 at 8:20am
It seems the "Group master" variable did not point correctly to the parent group. This code seems to work better:
if(userChart.Selection.Boxes.Count > 0)
  Group parent = de.MasterGroup;
  Group sub = de.SubordinateGroup;
  for(int k = 0; k < sub.AttachedObjects.Count; k++)
    Box b = (Box)sub.AttachedObjects[k];
    b.AttachTo(main, AttachToNode.TopLeft);
  rearrange();
