Normal Topic e.Confirm not working anymore (Read 8785 times)
bxsl
Dec 1st, 2006 at 5:16am
since i went from ver 4.0.2357.25099 to 4.1.0.22212 e.Confirm = False in ItemModifying is not working. In the old ver if you used this it would stop the item from moving but in the newer ver the item still moves please help
Private Sub Cal1_ItemModifying(ByVal sender As Object, ByVal e As MindFusion.Scheduling.WinForms.ItemModifyConfirmEventArgs) Handles cal1.ItemModifying
If e.Item.RecurrenceState <> RecurrenceState.None Then
res = MsgBox("This is a Recurring appointment, What would you like to change?" & vbNewLine & "To change just this occurrence click ‘Yes’ or" & vbNewLine & "to change the entire sirres click ‘No’ or click ‘Cancel’ to cancel" & vbNewLine & vbNewLine & "NB: by moving a Recurring appointment to a different day all Recurrence information will be lost", MsgBoxStyle.YesNoCancel)
'exit sub if the user selects cancel
If res = MsgBoxResult.Cancel Then
e.Confirm = False
Exit Sub
ElseIf res = MsgBoxResult.No Then
MsgBox("still to code")
e.Confirm = False
Exit Sub
End If
end sub
This was working fine untill I change dll to the newer one
« Last Edit: Dec 1st, 2006 at 6:17am by bxsl »
Re: e.Confirm not working anymore
Reply #1 - Dec 1st, 2006 at 7:03am
In the last release we changed the way items behave when their modification is not confirmed. Instead of retaining their original position, they move to the new position pointed to by the mouse, but the mouse cursor changes to a 'No' cursor to indicate that the modification is not allowed. Releasing the mouse under these circumstances should reset the item back to its original position. However showing up a form or in another way changing the focus away from the control during item modiciation causes the modification to be completed successfuly when the user gets back to the control (even though the modification was not confirmed in the event handler). This has been fixed. You can download the updated version from here:
https://mindfusion.org/_planner/_Planner.NET_41pre_trial14.zip
(This is a temporary link and is not guaranteed to work in the future.)
bxsl
Reply #2 - Dec 1st, 2006 at 9:53am
still not working with the new .dll using Version 4.1.0.18832 just doing same as before
Reply #3 - Dec 1st, 2006 at 12:47pm
When you close the dialog box that appears in the ItemModifying event handler, and release the mouse button, or click again if you have already released the mouse button while the dialog has been displayed, the item should revert back to its original position. Does it behave differently at your site?
bxsl
Reply #4 - Dec 1st, 2006 at 7:33pm
I made a new project with the new dll from *trial14.zip and it did the same. When you drag an item the msgbox comes up after you click the msg box the item moves one line, eg if you have the control setup for showing every minute in an hour and the item is at 9:00 and you try and moive it down after the msgbox and the e.Confirm = False the item will now be at 9:01. Same thing also if you try and make the item bigger e.g. change the length.
below is the code from my yest project.
Private Sub cal1_ItemModifying(ByVal sender As Object, ByVal e As MindFusion.Scheduling.WinForms.ItemModifyConfirmEventArgs) Handles cal1.ItemModifying
MsgBox("test")
e.Confirm = False
cal1.ResetDrag()
End Sub
bxsl
Reply #5 - Dec 3rd, 2006 at 11:12pm
this is still not working for me with the newly released version 4.1 :-[
Reply #6 - Dec 4th, 2006 at 6:58am
Here is another version, which I hope will fix the problem this time:
https://mindfusion.org/_planner/_Planner.NET_41_trial15.zip
(This is a temporary link and it is not guaranteed to work in the future.)
bxsl
Reply #7 - Dec 4th, 2006 at 8:41am
Thankyou, Thankyou and did I say Thankyou!!
Great job all working now
Cheers
Jason
