Normal Topic Overview Refresh (Read 1553 times)
clam
Overview Refresh
Dec 7th, 2006 at 11:36am
When I programmatically add a box to my chart, the overview control (in fitall mode) is not refreshed properly (the new box (or part of it) is visible but the area wasn't increased). When I then move the new box in the chart (by drag'n drop), the overview control gets refreshed correctly.
Calling overview.refresh or overview.update or flowchart.refresh or flowchart.update has no effect. How can I trigger the overview control to be correctly refreshed after I added a box?
Re: Overview Refresh
Reply #1 - Dec 7th, 2006 at 12:02pm
Probably the Overview uses FlowChart.DocExtents to decide what part of the chart to draw. So if you create a box out of the current document area, it won't be visible. Calling FitDocToObjects should fix that.
clam
Reply #2 - Dec 7th, 2006 at 12:06pm
Yes, that worked. Thank you very much!
