Normal Topic LayeredLayout (Read 1101 times)
chrise
LayeredLayout
Dec 11th, 2006 at 8:24am
How does LayeredLayout routearrows? I have a graph that I use Layerlayout to arrange and then allow the user to move boxes after the move I would like to route the arrows however the arrows are routed completely different.  Is there default for the routeoptions for the layout?
Re: LayeredLayout
Reply #1 - Dec 11th, 2006 at 1:01pm
LayeredLayout doesn't route arrows at all. Instead it adds some virtual nodes to each layer while arranging, so that connections are made only between adjacent layers. Arrows that cross several layers have their segments aligned to the virtual nodes positions, and in the end the virtual nodes are removed.
The only layout that uses the built-in routing is GridLayout.
