Normal Topic Enter & Leave of box event handling .. (Read 1280 times)
parkwonwoo
Open the Podbay Doors
HAL!
Dec 14th, 2006 at 12:51am
I need the "MouseEnter & MouseLeave of box event handling" with C# .NET.
Is it Possible ?
Thanks in advance.
- OS: XP sp2
- RAD: C# Builder 2006
- .NET 2.0/1.1 sp2
- FCX v 4.1 Trial (Now Purchasing)
OS: WinXP sp2&&RAD: Borland Delphi7, C++Builder6, JBuilder9&&FrameWork: VCL+Win32 or J2SE&&FCX: FCX 4.1.x
Re: Enter & Leave of box event handling ..
Reply #1 - Dec 14th, 2006 at 5:49am
You will need to do it yourself by handling the MouseMove event and checking what box is under the mouse position with the GetBoxAt method. Keep a reference to the last box detected, so you can test if the mouse moved away from it.
