Normal Topic InPlaceEditing - Box resizing (Read 1603 times)
David Long
Dec 18th, 2006 at 2:30pm
When a user finishes editing the contents of a box I resize the box by using:
           box.FitSizeToText(FitSize.KeepWidth);
Is there any way of resizing the box as the user types.  The event I'm looking for (Box Contents Changing event) does not seem to be available.
DavidL
Re: InPlaceEditing - Box resizing
Reply #1 - Dec 18th, 2006 at 5:48pm
You can handle the TextBox.TextChanged event to resize the box as the user types.
Box currentBox;
TextBox textBox;
private void fc_EnterInplaceEditMode(object sender, MindFusion.Diagramming.WinForms.InplaceEditArgs e)
   currentBox = e.Node as Box;
   textBox = e.TextBox;
   textBox.SelectionStart = e.TextBox.Text.Length;
   textBox.TextChanged += new EventHandler(TextBox_TextChanged);
private void TextBox_TextChanged(object sender, EventArgs e)
   Box temp = new Box(fc);
   RectangleF rect = currentBox.BoundingRect;
   rect.Inflate(10, 10);
   temp.BoundingRect = rect;
   temp.Text = textBox.Text;
   temp.FitSizeToText(FitSize.KeepRatio);
   currentBox.BoundingRect = temp.BoundingRect;
   Rectangle clientRect = fc.DocToClient(temp.BoundingRect);
   textBox.Location = clientRect.Location;
   textBox.Size = clientRect.Size;
David Long
Reply #2 - Dec 20th, 2006 at 9:30am
Thanks, that saved a lot of thinking!
Had to remove the line:
for it to work perfectly.
DavidL
