Normal Topic About Layout the flowChart (Read 2240 times)
grayhound
Jan 5th, 2007 at 3:00am
the flowchart is below: Pool1 is a Box. There is a Goup, all the box is in the group. every pool is a master object of a group.There may be more than one pool on the flowchart.
I want to Layout the box in Pool1, and i don't want to layout the Pool.
Is there some good idea?
Re: About Layout the flowChart
Reply #1 - Jan 5th, 2007 at 5:42am
We could implement a way to layout that automatically, if we can ignore the links that go between different pools. Then you could call Route() on such links, so at least they do not cross nodes. Will that be ok?
grayhound
Reply #2 - Jan 8th, 2007 at 1:08am
the importance is that I want to lay out the box but not arrow.
Reply #3 - Jan 8th, 2007 at 10:24am
Ok, we'll try to add to the 4.2.3 release an Arrange(BoxCollection) method. Until then, when arranging a "pool", enable the IgnoreLayout property of all boxes outside the pool so that the layout algorithm does not move them. Doing that for all pools and using the LayoutArea property should arrange the boxes nicely, each group in their respective area. At this time the LayoutArea property is available only with the spring and anneal layouts.
