Normal Topic Adding an inherited Box to an inherited FlowChart? (Read 2317 times)
ChrisBrowne
Jan 11th, 2007 at 12:13pm
Hi there Mind Fusion!
We're using your FlowChartX controls for the front end of our new application, and we wish to add some custom functionality to the FlowChartX.Box class to make it change its Me.Pen color with certain state changes in our app.
I've created a new class inheriting from your FlowChart class and overridden the CreateBox to add my inherited Box class which I've extended with functionality to change its .Pen.Color when the state changes.
However when I execute the CreateBox method, the box isn't shown on the FlowChart. I'm not too sure what to do. Here is my code...
Public Class Chart
    Inherits MindFusion.FlowChartX.FlowChart
    Public Overloads Function CreateBox(ByVal x As Single, _
						    ByVal y As Single, _
						    ByVal width As Single, _
						    ByVal height As Single) As ActionBox
	  Dim newActionBox As ActionBox = New ActionBox(Me)
	  newActionBox.Move(x, y)
	  newActionBox.Resize(width, height)
	  MyBase.Boxes.Add(newActionBox)
	  Return newActionBox
    End Function
End Class
Public Class ActionBox
    Inherits MindFusion.FlowChartX.Box
    Private _action As Action = Nothing
    Public Sub New(ByVal flowChart As MindFusion.FlowChartX.FlowChart)
	  MyBase.New(flowChart)
    End Sub
    Public Property Action() As Action
	  Get
		Return _action
	  End Get
	  Set(ByVal value As Action)
		_action = value
		AddHandler _action.Highlight, AddressOf _action_Highlight
		AddHandler _action.UnHighlight, AddressOf _action_UnHighlight
	  End Set
    End Property
    Private Sub _action_Highlight(ByVal sender As Object, ByVal e As EventArgs)
	  Me.Pen.Color = Drawing.Color.Yellow
    End Sub
    Private Sub _action_UnHighlight(ByVal sender As Object, ByVal e As EventArgs)
	  Me.Pen.Color = Drawing.Color.Black
    End Sub
End Class
Can you help?
Cheers,
Chris
Re: Adding an inherited Box to an inherited FlowCh
Reply #1 - Jan 11th, 2007 at 12:49pm
Hi Chris!
The control draws all items that are in the ChartObjects collection, so you will need to add the box there too. Or better call
MyBase.Add(newActionBox)
instead of
The FlowChart.Add method adds the box to both the Boxes and ChartObjects collections and creates an undo/redo record for the operation.
ChrisBrowne
Reply #2 - Jan 11th, 2007 at 1:09pm
That's brilliant!
Thanks Stoyan  Grin
