Normal Topic Trial license using VS2005 on XP x64 (Read 3998 times)
dormeur
Never mistake activity
for achievement
Jan 19th, 2007 at 6:58am
I've downloaded and installed the trial version of the Planner component.  I can use the component in the Visual Studio 2005 designer, but when I want to compile the project I get an error that a design-time license could not be found:
"Exception occurred creating type 'MindFusion.Scheduling.WinForms.Calendar, Calendar, Version=4.1.0.19866, Culture=neutral, PublicKeyToken=9bbcdceda2685d38' System.ComponentModel.LicenseException: Couldn''t get design-time license for ''MindFusion.Scheduling.WinForms.Calendar''"
I'm building this project on .NET 2.0 but I'm using target platform x86 (so no 64-bit).
However, when I build the source code using Nant on the command-line I get no errors and the application works fine.
This is what's in the licenses.licx file:
Does anybody know how I can fix this?  I'm using VS 2005 Standard Edition on Windows XP x64  (AMD x64 dual core) and .NET 2.0.
Regards
Re: Trial license using VS2005 on XP x64
Reply #1 - Jan 19th, 2007 at 7:31am
Can you please try to set the PublicKeyToken in the licenses.licx file to an empty string and try again? The licenses.licx file should look like this after the change:
For some reason the contents of the license file did not correspond to the referenced Planner.NET assembly.
dormeur
for achievement
Reply #2 - Jan 19th, 2007 at 7:41am
Thanks, but that didn't help.  I've cleared the PublicKeyToken, but now I get another error:
'The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)'
dormeur
for achievement
Reply #3 - Jan 19th, 2007 at 8:37am
Update: clearing the entire entry in the licenses.licx file fixes the problem!  The project compiles and the applications runs.
Regards
Reply #4 - Jan 19th, 2007 at 5:15pm
Clearing the line from the licenses.licx might work with the trial version , but I am not sure about the licensed one.
If you are using a 64-bit Windows, the problem might happen because the MSI service installs the control's design time registry key under the 32-bit section of the registry. But then .NET runs 64-bit, and the control looks for the design time key under the 64 bit registry branch. You can resolve this by copying this key:
HKEY_LOCAL_MACHINE\SOFTWARE\MindFusion Limited\ComponentLicenses
to the same path under the Wow64  branch of the registry.
