Normal Topic Offset header text. (Read 1957 times)
bxsl
Offset header text.
Jan 29th, 2007 at 8:21am
I am displaying my own icons in the header section (next to the recurrence icon) of each item in a timetable view the problem is if I have lots of columns displayed making the item very small or lots of text in the header the header text goes under the icons. Is there an Offset for the text in a header? I tried the text alignment but this does not help me as I would still like the text alignment to be to the left
Re: Offset header text.
Reply #1 - Jan 29th, 2007 at 9:02am
I presume you are using custom drawing in order to display your icon next to the recurrence icon. Have you tried assigning the icon to the Style.Image property of the item's style? Anyway, we could add a TextOffset property to the Style class if you desire, which will determine the offset of the item's text relative to the current drawing origin.
bxsl
Reply #2 - Jan 29th, 2007 at 6:27pm
That would be great if you could add that, I did try the Style.ImageIndex but found that on a recurrence item if you change the icon on an exception then it changes it on all of the recurrence items also.
