Normal Topic Simple database example (Read 5167 times)
BK
Feb 1st, 2007 at 8:31am
We are in the process of witing a small service management and scheduling system for a small customer.
The Ressource view of Planner.net seems to be precisely what we are after. Trouble is the customer would like a demo of what this would look like really soon.
So does anyone have a simple application using this view based on e.g. a small database with a few tables describing e.g. persons, appointements (typically 0,5 to 4 hours), so that we could make a quick (but dirty) mock up demonstration of the usage?
BK
Re: Simple database example
Reply #1 - Feb 1st, 2007 at 8:32am
Ups, I forgot to say that I only has to provide a viewing capability. the intereface is not necessarily being used for making new appointments
Reply #2 - Feb 1st, 2007 at 12:12pm
I have prepared a small sample for .NET Compact Framework 2.0, which illustrates the resource view and how to load contact and appointment data from a data source. The data source in my case is not a database. However, it shows how to import schedule data from an arbitrary source.
You can download the sample from here:
https://mindfusion.org/_samples/_sample_ResourceView.zip
BK
Reply #3 - Feb 1st, 2007 at 1:38pm
Thanks a lot! That would really well, except we do not run Compact Framework and have problems getting it to work. Would it be too much to ask you to prepare it for normal XP, using the normal framework?
Reply #4 - Feb 1st, 2007 at 2:18pm
Here is the very same sample ported to .NET Framework:
https://mindfusion.org/_samples/_sample_ResourceView2.zip
This one uses .NET Framework 1.1 since I am not sure which one you are using. Let me know if you need a build for .NET 2.0.
Reply #5 - Feb 2nd, 2007 at 6:24am
Here is the sample ported for the .NET 2.0:
https://mindfusion.org/_samples/_sample_ResourceView3_20.zip
