Normal Topic Reminders in VB (Read 2871 times)
bxsl
Reminders in VB
Feb 1st, 2007 at 10:35am
can you please show me how to use the ItemReminderTriggered in vb.net Have had a play but can get it going...... Its late @ night and I am having brain fade!
Re: Reminders in VB
Reply #1 - Feb 1st, 2007 at 1:17pm
You have to create a new reminder and associate it with an item. Then, when the reminder's time comes this event is fired. The following example attaches a leading reminder to an existing item. The reminder will be triggered (i.e. the event will be fired) 5 minutes before the item's actual start time:
Dim r As New MindFusion.Scheduling.Reminder
r.Type = MindFusion.Scheduling.ReminderType.Leading
r.TimeInterval = TimeSpan.FromMinutes(5)
item.Reminder = r
Also, make sure that Schedule.DisableReminders is set to false (it is set to false by default). Reminders are checked regularly every 30 seconds by default. You can modify this interval through the Schedule.RemindersCheckInterval property.
I hope this helps.
bxsl
Re: Reminders in VB
Reply #2 - Feb 1st, 2007 at 6:30pm
Sorry that part I get its this part I need in vb
calendar.Schedule.ItemreminderTriggered +=
  new MindFusion.Scheduling.ItemEventHandler(OnItemreminder);
private void OnItemreminder(object sender, MindFusion.Scheduling.ItemEventArgs e)
  MessageBox.Show(e.Item.reminder.Message);
Re: Reminders in VB
Reply #3 - Feb 1st, 2007 at 7:07pm
Use the VB.NET AddHandler method -
AddHandler calendar.Schedule.ItemReminderTriggered, AddressOf OnItemReminder
bxsl
Re: Reminders in VB
Reply #4 - Feb 1st, 2007 at 8:12pm
Cheers, Grin Grin My BAD!!
