Hi there,
This is the final preview of NetDiagram before we release the beta version -
https://www.mindfusion.org/_beta/NetDiagram.zipAnd the new stuff is -
* support for Firefox 2
* support for the RTM version of Microsoft AJAX for ASP.NET
* ClientSideMode property, which can be set to JavaApplet or ImageMap
* the ImageMap mode can be used when you don't won't to rely on the Java runtime being present on end-users systems. In that mode NetDiagram generates an image and an image map representing the diagram nodes. You must add ImageGen.aspx to your project in order to generate the diagram images on the server side.
* In ImageMap mode, the Hyperlink property of items can be used to load another page or to execute a client side script. If the HyperLink of an object is not set, NetDiagram will raise a server side event, e.g. BoxClicked or ArrowClicked.
* The ImageMap mode also implements expand/collapse functionality for trees and raises the TreeCollapsed/TreeExpanded server side events.
We believe that's enough for the first version of the component
Now we'll complete the help file and create a few more samples and should be able to release NetDiagram 1.0 by the end of February.
g.
