Normal Topic Tutorial 4. clarification (Read 5613 times)
gerardo
Feb 5th, 2007 at 4:40pm
I'm working creating my own custom schedule item class like in the tutorial 4, so let me use the tutorial to expain my question.
The property _kept is initialized TRUE in the constructor.
So using the code below(change Kept to false), everytime the user clicks the appointment the message text is showing:
This is our item!. Kept is True.
when the value for Kept must be false.
If I remove the recurrent part of the code the value will be false as expected but for recurrent appointments probably I'm missing something in the code.
Thanks in advance for any help.
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Schedule.RegisterItemClass(GetType(MyApp), "myapp", 1)
calendar.InteractiveItemType = GetType(MyApp)
'added by gerardo
Dim newapp As MyApp
newapp = New MyApp
newapp.DescriptionText = "TEst 01"
newapp.HeaderText = "header 01"
newapp.Kept = False
newapp.StartTime = New DateTime(2007, 2, 5, 8, 0, 0)
newapp.EndTime = New DateTime(2007, 2, 5, 10, 30, 0)
Dim rec As Recurrence = New Recurrence
rec.Pattern = RecurrencePattern.Daily
rec.StartDate = New DateTime(2007, 1, 10)
rec.RecurrenceEnd = RecurrenceEnd.Never
newapp.Recurrence = rec
calendar.Schedule.Items.Add(newapp)
calendar.Date = New Date(2007, 2, 5)
End Sub
Private Sub calendar_ItemClick(ByVal sender As Object, ByVal e As MindFusion.Scheduling.WinForms.ItemMouseEventArgs) Handles calendar.ItemClick
If TypeOf e.Item Is MyApp Then
Dim myAppointment As MyApp
myAppointment = e.Item
calendar.ResetDrag()
MessageBox.Show("This is our item!. Kept is " + myAppointment.Kept.ToString())
End If
Re: Tutorial 4. clarification
Reply #1 - Feb 5th, 2007 at 5:00pm
Further down in tutorial 4 there is a part about recurrences, that shows how to implement cloning of custom fields -
protected override void CopyOccurrence(Item master)
	base.CopyOccurrence(master);
	kept = (master as MyApp).Kept;
gerardo
Reply #2 - Feb 5th, 2007 at 5:08pm
I read that part.
and If you replace the code in the tutorial for the methods:
Form1_Load
calendar_ItemClick
with the code that I provided in the original post, your will understand my question, because I use the class MyApp as is definided in the tutorial including the method: CopyOccurrence
gerardo
Reply #3 - Feb 5th, 2007 at 5:16pm
this is the implementation on MyApp that I'm using for CopyOcurrence:
    Protected Overloads Sub CopyOccurrence(ByVal master As Item)
       MyBase.CopyOccurrence(master)
       _kept = CType(master, MyApp).Kept
    End Sub
Reply #4 - Feb 5th, 2007 at 5:27pm
Try defining the method with the Overrides keyword instead of Overloads.
gerardo
Reply #5 - Feb 5th, 2007 at 5:40pm
That was the problem.... Thanks. Smiley
Reply #6 - Feb 5th, 2007 at 5:46pm
