Normal Topic Anchoring Pattern with tables (Read 1926 times)
kkt
Feb 9th, 2007 at 1:03pm
I am evaluating the control. Downloaded version 4.3 (beta).I am interested in the outcome of auto-layout algorithms mainly.
When I create a simple chart with about 10 boxes , link them randomly I have a very satisfactory result from the tree layout algorithm.
I have implemented a simple top-to-bottom AnchoringPattern. I want to have my outgoing arrows starting from the bottom-middle of my box and my incoming arrows ending at the top-middle of the box. It all works fine. But when I change the Box to a table, the anchoring points chosen do not follow my pattern. Any ideas? The code is the same. Only the creation of the box is changed and it creates a table instead (and the anchoring pattern is assigned). ???
Thanks helping
Re: Anchoring Pattern with tables
Reply #1 - Feb 9th, 2007 at 2:03pm
The destination of an arrow can be either a table, or a row of the table. The latter is useful in DB diagram where you could show the relationship between individual fields. The Table.AnchorPattern does not influence arrows connected to rows. Try setting the Table.LinkStyle to "Table" before drawing arrows - that will make arrows connect to the table and not to a distinct row.
kkt
Reply #2 - Feb 12th, 2007 at 5:44am
Thanks for the quick response. Works out a treat!
