Normal Topic Declaring the Object Variable of FCX outside (Read 2166 times)
parkwonwoo
Open the Podbay Doors
HAL!
Feb 13th, 2007 at 6:02am
Hi.
// FCX exist in Form1 ------------------------------------------
procedure Form1.aaa(NodeID: integer);
var
  FB, BB: IBoxItem;
begin
This Code works good.
But Below code does not.
// FCX not exist in Form2 ------------------------------------------
procedure Form2.bbb(NodeID: integer);
var
  FB, BB: IBoxItem;
begin
ei. Can I declare the Object Variable of FCX outside the Form1(Only Form1 Have the FCX Control).
Thanks in advance.
OS: WinXP sp2&&RAD: Borland Delphi7, C++Builder6, JBuilder9&&FrameWork: VCL+Win32 or J2SE&&FCX: FCX 4.1.x
Re: Declaring the Object Variable of FCX outside
Reply #1 - Feb 13th, 2007 at 6:09am
Perhaps you should add the unit imported from the FlowChartX type library to the "uses" clause in your second form.
parkwonwoo
HAL!
Reply #2 - Feb 13th, 2007 at 7:04am
Thanks.
It works good.
