Normal Topic VisibleDays and NumberOfDays (Read 2648 times)
Jeffry
Feb 14th, 2007 at 4:31pm
I set the DayRangeSettings.NumberOfDays to 1 and after that the DayRangeSettings.VisibleDays to 1 in the properties window.
When you then look at the designer class it says:
DayRangeSettings.NumberOfDays = 1;
DayRangeSettings.VisibleDays = 1;
Because the default for VisibleDays = 7 and NumberOfDays is set before VisibleDays it throws an exception: Specified argument was out of the range of valid values. Parameter name: '1' is not a valid value for 'NumberOfDays'. 'NumberOfDays' must be greater than or equal to 'VisibleDays'.
Re: VisibleDays and NumberOfDays
Reply #1 - Feb 14th, 2007 at 6:03pm
Thank you for letting us know of this issue. Our developer will take a look into it tomorrow. For now set the properties from the form.Load event in the opposite order Wink
