Normal Topic Programatically creating a table with rows (Read 2946 times)
Charter
Feb 19th, 2007 at 11:28pm
I would like to create a one-column table that is populated with row data:
Here is some code:
FlowChart chart = new FlowChart();
Table         table = new Table(chart);
chart.Behavior = BehaviorType.DoNothing;
table.ColumnCount = 1;
for(int i = 0; i < 10; i++)
       table.AddRow();
      table[0,i].Text = "Hello";
table.ResizeToFitText();
chart.Add(table);
However when I attempt to add the chart to a Windows Form, nothing appears.
Ideas as to where I am going wrong?
Re: Programatically creating a table with rows
Reply #1 - Feb 20th, 2007 at 5:52am
Do you mean the flowchart control doesn't appear, or the table? That code has some compilation errors - maybe you haven't noticed them and ran an older version of the compiled exe -
error CS1501: No overload for method 'ResizeToFitText' takes '0' arguments
You must pass a boolean argument that specifies whether the caption text should be measured as well when calculating the table size.
Charter
Reply #2 - Feb 20th, 2007 at 4:56pm
Oops...sorry about forgetting the boolean. In any event, that does not seem to make any difference. So change that to:
table.ResizeToFitText(true);
After the creation code from the previous post (along with the correction above) I have this line of code in my Windows Form:
this.Controls.Add(chart);
I tried adding the Table directly, but it does not seem to derive from Control, whereas FlowChart does. Also, if I just drag a FlowChart object from the Toolbox to the form, the above instantiation code is what is generated. Nevertheless, the control does not appear on the form.
Reply #3 - Feb 20th, 2007 at 5:29pm
What if you set the flowChart.Bounds after adding it to the form? Also try setting flowchart.Visible and call BringToFront, or otherwise the control might remain hidden.
Charter
Reply #4 - Feb 20th, 2007 at 7:13pm
OK, setting chart.Bounds did the trick. It turns out that  chart.Visible was already set to True and BringToFront() did not need to be called.
It's strange though: I would have thought that the FlowChart should expand to display all tables (or boxes, etc.) added to it automatically.
More assumptions broken  Smiley. Thanks for the help.
