Normal Topic Arrow buglet? (Read 2565 times)
Charter
Arrow buglet?
Feb 28th, 2007 at 7:00pm
I created a flowchart with two tables in it, and attached arrows to each of the nodes.
I set the chart's behavior to Modify and set the Locked property of each of the tables. When I then tried to move an arrow to another node in the second table, it would not move. I then removed the line of code that set Locked to true, and everything worked.
Is this a buglet or a feature? Is there some way to restrict modification of the contents, size, and location of a table while permitting arrows to be attached to node borders?
Also: I can't get cascading arrows to work at all. Any pointers there would also be helpful.
Re: Arrow buglet?
Reply #1 - Feb 28th, 2007 at 7:07pm
Perhaps the control doesn't let you attach arrows to locked objects. Try setting Table.EnabledHandles = None instead of locking the tables. What does exactly happen with your cascading arrows?
Charter
Re: Arrow buglet?
Reply #2 - Feb 28th, 2007 at 7:22pm
OK, setting EnableHandles to Handles.None works fine. Sorry to ask such simple questions.
As to cascading arrows: nothing happens. They just stay stuck to the node borders and will not move. I have created them like this:
Arrow arrow;
for(int i = 0; i < 10; i++)
       arrow = chart.CreateArrow(table1, i, table2, i);
       arrow.AllowMoveEnd = true;
       arrow.AllowMoveStart = false;
       arrow.ArrowHead = ArrowHead.Rhombus;
       arrow.CascadeOrientation = Orientation.Horizontal;
       arrow.Dynamic = true;
       arrow.SegmentCount = 2;
       arrow.SnapToNodeBorder = true;
       arrow.Style = ArrowStyle.Cascading;
I have verified that these properties are set for all arrows in the chart.Arrows collection. Nevertheless,
the arrows just stay stuck. If I change the Style to Polyline, the arrows are movable.
I would like arrows that can be moved up or down in a table and when they are moved they create a new vertical line segment when the endpoint moves. I think this is one use of cascading arrows, no?
Re: Arrow buglet?
Reply #3 - Feb 28th, 2007 at 7:37pm
What if you set arrow.SegmentCount = 3? With 2 segments the last points might coincide, and the point next-to-last might prevent you from grabbing the arrow end and moving it.
Charter
Re: Arrow buglet?
Reply #4 - Feb 28th, 2007 at 7:42pm
That did it, thanks. I didn't even think about the endpoints co-inciding. I was thinking that when the segments were created that the distance that the arrow needed to traverse would have been split in half, and a segment generated for each half.
Everything works great now, thanks.
