Normal Topic Arrow auto routing questions (Read 1562 times)
jstraylor
Mar 5th, 2007 at 5:43pm
I am using FC.NET 4.3 and have a couple of questions about auto-routing arrows as I can't seem to make them behave as I would like them to.
I am drawing a simple electrical layout diagram and need the arrows to always have a vertical orientation at the start and end, so I set those properties in the RoutingOptions.  The arrowstyle is set to Cascading.  However, sometimes when I move a box up or down in the chart the start and end segments switch to horizontal.  Do I need to trap a routing event and force the orientation to what I need??  If so, which event should I trap??
Second observation/question.   When I allow the arrows to autoroute the arrow lines actually overlap (they are drawn right on top of each other).  I need to force a space between arrow lines so that the diagram is readable.  Do I do this in one of the routing events??  Or, do I just need to set some different RoutingOptions??
Thank you again,
Jeff
Alex
Re: Arrow auto routing questions
Reply #1 - Mar 28th, 2007 at 4:46am
i got the exact same Problem Sad, and no solution to this so far.
Best regards,
Alex
Reply #2 - Mar 28th, 2007 at 5:11am
It seems that was a double post; please check if the tips here will help -
http://mindfusion.org/cgi/Forum/YaBB.pl?board=fcnet_disc;action=display;num=1173...
