Normal Topic ARROW AND IMAGE (Read 1312 times)
alesdario
ARROW AND IMAGE
Mar 7th, 2007 at 6:43am
Hi. Can i connect an arrow with an image.
I want that the image will always linked at the center of the Arrow. Is it possible?
Re: ARROW AND IMAGE
Reply #1 - Mar 7th, 2007 at 7:01am
Do you need to set an image as the arrow's Origin or Destination node? Or you need to attach an image to the arrow so that the image follows the arrow center ? You can load the image into a box and set box.Transparent = true. If the former case, assign the box to the arrow's Origin or Destination; if the latter, use the box.AttachTo method to link it to the arrow.
