Normal Topic Method AttachTo (Read 1590 times)
alesdario
Method AttachTo
Mar 7th, 2007 at 8:05am
When i use the method AttachTo, i use this contructor:
AttachTo(Arrow arrow, AttachToArrow attType,int index).
Can yuo explain me what is index?
Tanks.
Re: Method AttachTo
Reply #1 - Mar 7th, 2007 at 9:23am
Depending on the attachType argument, the index value refers either to the index of an arrow segment, or to the index of a control point.
If your arrows have only one segment, you can calculate its center like this:
PointCollection pts = arrow.ControlPoints;
PointF center = new PointF((pts[0].X + pts[1].X) / 2, (pts[0].Y + pts[1].Y) / 2);
Then create a box at the centerPoint location so the image center point coincides with the arrow center:
Box imgBox = fc.CreateBox(center.X - imgSize / 2, center.Y - imgSize / 2, imgSize, imgSize);
imgBox.Image = ...;
imgBox.Transparent = true;
Finally attach to the only arrow segment:
imgBox.AttachTo(arrow, AttachToArrow.Segment, 0);
alesdario
Re: Method AttachTo
Reply #2 - Mar 7th, 2007 at 11:30am
very tanks.
